I've used an H80i for almost a year now to cool an FX-8350 and an i5-4670K, and I'm starting to look at better options due to interest in water cooling the GPU, and the fact that closed loop liquid coolers aren't really as effective as the "real" thing. I'm limited to using a single 120mm radiator, so how much cooling performance could I expect if I set up a 120mm x 80mm Alphacool radiator with a Swiftech Apogee Drive II block+pump, and a Swiftech MCRES V2 reservoir? And what makes closed loop liquid coolers inferior to custom loops? I won't add in a liquid cooled GPU until later, but for now the parts I need to set up my custom loop will cost at least $250, I need to know if it's really worth it. And as extra information, I have a Fractal Design Node 304 case and I'm running a 4670K.
