Sign-in / Sign-up
Solved
GTX 560 Triple Monitor Setup Questions.
  • Gtx
  • Monitors
  • Graphics
Last response: in Displays
December 18, 2013 6:43:19 AM
Hi,
I was wondering whether two GTX 560's would be able to handle three 23" monitors with each of them running at 1920x1080?
I currently have one of these and i intend to buy another if the setup would work well.
http://www.gigabyte.com/products/product-page.aspx?pid=....
I intend to use the setup to play games on medium settings,
Thanks.
More about : gtx 560 triple monitor setup questions
a c 176 C Monitor
December 18, 2013 6:50:27 AM
Depends on the games, but my guess would be it wouldn't run very well. I had3 SLI'd GTX 580s on a 5760x1080 setup and it struggled in most games at that resolution.
m
l
December 18, 2013 7:25:48 AM
Do you know of any cards that could handle that resolution, be playable and run well at med-high settings?
My budget is around £200.
Thanks.
m
l
Best solution
a c 176 C Monitor
December 18, 2013 1:21:12 PM
Not at that budget. You are going to want a card with 3Gb or more vram. The biggest bottleneck on my 580's seemed to be the lack of vram as they were only the 1.5Gb cards. I now run 2 4gb 770's and it did much better with the 3 monitors. For a single card config Something like a GTX 780 or R9-290 should be able to play most games at that res on medium to high settings.
