Hello all,
I've done a lot of reading on these topics, understand negative and positive pressure and all that, but wanted to run my ideas by you before I started the build. My Fractal Design Define Mini will house an i7 4770K CPU, an ASUS GRYPHON motherboard (without the armour kit) and eventually an EVGA GTX 770 video card with the ACX cooler (not fully decided on which model to get yet). I am planning on mild overclocking, but not to begin with, so I am sticking to the stock Intel cooler for now. My case fans configuration will be as follows:
- Noctua NF-P12 PWM at the bottom front (INTAKE)
- Noctua NF-P12 PWM at the top front (INTAKE)
- Noctua NF-A14 PWM at the top (EXHAUST)
- Noctua NF-A14 PWM at the side (INTAKE or EXHAUST -- see my first question below)
- Noctua NF-S12A at the back (EXHAUST)
- Noctua NF-S12A at the bottom (INTAKE or EXHAUST -- see my second question below)
My questions:
- I know that traditionally, the side fan is used for intake, to help cool the video card, but does it not stand to reason that whatever cool air it pushes into the case, it will simply be sucked out by the rear and top fans before it has a chance to do anything to the video card? If so, would it not make more sense to set it up for exhaust? There will be plenty of cool air coming in from the top front fan, as I am removing the top hard drive cage from the case. Another reason for this would be that the cool air coming in from the side would simply mix with the hot air coming off the stock Intel processor cooler, likely negating any of its potential/questionable benefits.
- I know that the bottom fan is also, traditionally, used for intake, but since the fans on the video card are blowing down, and the front bottom fan is pushing air into the same area of the case (i.e. below the video card), doesn't it make more sense to have the bottom fan set up for exhaust? (Yes, the bottom front intake is also responsible for cooling the SSD and hard drive that will be mounted in the bottom drive cage, but I don't think that's a HUGE concern, no?)
All this said, I am planning to upgrade to a Noctua NH-U12S processor cooler in the near future. What is the optimal mounting position for such a cooler--with the fan blowing towards the back or the top of the case? And should the fan be on the side of the cooler closer to the top or back of the case (depending on best orientation), or on the side of the cooler closer to the bottom or front of the case (again, depending on best orientation)?
Your thoughts on any or all these matters would be greatly appreciated. Thanks so much!
Dany
My questions:
Dany
