Cooler Master HAF 912 Fans - Not allowing the motherboard to process power on/boot sequence?
  • Cooler Master
  • Power Supplies
  • Motherboards
  • Boot
  • Fan Controller
December 20, 2013 10:58:06 AM
So I've connected everything together and my PC starts up fine asking for a boot drive when I *dont* connect the two fans attached to my case directly onto my motherboard, onto where it says "Sys_Fan1".
As they're connected to the power supply, they still come on when I remove that cable from my motherboard, and the computer starts normally again.
It seems that connecting the fans to the motherboard make the computer completely freeze and not want to start up at all - not the power supply, no fans move, nothing.
Am I doing something wrong here? It's my first time building.
More about : cooler master haf 912 fans allowing motherboard process power boot sequence
December 20, 2013 5:09:43 PM
Try installing the driver and bios updates.
December 20, 2013 5:11:21 PM
Actually, do you have the main power connector and the supplemental power plugged into the motherboard?
