Current Specs
Motherboard: Z68X-UD5-B3
Video Card: Ati Radeon Hd 5770 1Gb
Processor: Intel I5-2500k 3.30Ghz(Oc'd to 3.6Ghz)
Memory: 16Gb G-Skill PC3-12800(1600MHz)
Case: Antec 900
SSD: 120gb Vertex 2
HDD: 2 1TB 7200Rpm running in Raid 1 for backup
Powersupply: 650w
Hello, thank you for your time. I normally build my own computer and get by, but today I decided I'd ask the community their opinions. My current thoughts as of now are as follows....
Motherboard: The Z68X-UD5-B3 has done me well. I've had a few weird issues with it that don't really bother me.
Video Card: The 5770 is the most outdated thing in my computer. Problem is if I update the video card to something Pci express 3.0, I feel that my motherboard bottle necking it is silly(although it's not like that is a problem with the current games out there right now I feel).
Processor: The I-2500k has also done me well, but when I do stream(which isn't very often) I max it far to easily. Whether or not I upgrade it or leave it the same, I am considering getting a decent heat-sink so I can overclock without worry.
Memory: They are doing me well, I don't see the need to upgrade unless I get a new motherboard it doesn't support.
Case: Been around for many years. If the pieces fit and I still have good airflow, it works.
SSD: Not the Ssd I originally wanted, but it is fine.
HDD: Also fine
Powersupply: I have had this guy as long as I've had the case. He's a champ so far.
So what do you recommend I do with the $500-$950 budget from memoryexpress.com, Tigerdirect.ca, Newegg.ca, or any other I might be forgetting?
Case: Antec 900
SSD: 120gb Vertex 2
Powersupply: 650w
HDD: Also fine
