Did you mean $380
http://www.newegg.com/Product/Product.aspx?Item=N82E16824160162&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
If you did mean 38000 then
394 but have a higher resolution
http://www.newegg.com/Product/Product.aspx?Item=9SIA2RY10G0367&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Monitors%20-%20LCD%20Flat%20Panel-_-QNIX-_-9SIA2RY10G0367&cm_sp=&AID=10440897&PID=3938566&SID=
Did you mean $380
ASUS VG248QE Black 24" 144Hz 1ms, currently $270 at newegg. I use one with my 2 680's in SLI, love being able to run over 60 frames, max settings, without v-sync, no tearing.
