I am about to order some parts and build a new, small gaming computer. I already have a full size atx desktop but it takes up too much space and I want to connect the computer to my TV so it makes more space for my other computer. I already have a Corsair 550W PSU, a 250 gig HHD, which I am going to reformat, and a XFX HD 6970. These are the other parts I am ordering for my new build -
case Antec ISK600
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129198
mobo GIGABYTE GA-F2A88XN-WIFI FM2+ / FM2
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128663
And then I plan to buy the AMD Kaveri when it comes out on the 14th, which hopefully it is in my price range (under $70) and Newegg has it. If not, then I plan to get either http://www.newegg.com/Product/Product.aspx?Item=N82E16819113329
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113283
I plan to buy 4 gigs of DDR3 RAM, a slim DVD drive, and Windows 7 or 8 - Which OS is better for gaming/better all around?
How do all my parts look? Opinions? Will everything be compatible with each other?
case Antec ISK600
or
