Is this Power Supply overkill for my build?
  • Gaming
  • Power Supplies
  • Cases
  • Components
  • Build
Last response: in Components
Corsair CXM 750 or CXM 600?
Total: 0 vote
  • CXM 750W
  • 0 %
  • CXM 600W
  • 0 %
January 10, 2014 3:18:39 PM
I plan on building a new gaming rig where I'll be gaming (obviously) and rendering videos for my YouTube channel. These are the specs I'll be running:
Case - Rosewill BlackHawk ATX Case
(http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
CPU - AMD FX-6300 with Stock Heatsink
Motherboard - ASUS M5A97 R2.0 AM3+
RAM - G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 Mhz
Graphics Card - Gigabyte Radeon R9 270X 4GB Edition (yes they make those) (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
OS - Windows 8.1 (64-bit)
SSD - Samsung 840 EVO 120GB
HDD - Western Digital 1TB Caviar Blue
Optical Drive - ASUS DVD Writer
Card Reader - Rosewill Multi-card Reader
Fan Controller - NZXT Sentry-2 5.25" Touch Screen Fan Controller
Now the one thing I'm missing is my Power Supply. I wanna get either a Corsair CXM 600 Semi-Modular PSU or the CXM 750 PSU. I will have a decent amount of USB ports occupied but now with external hard drives or anything. Is the 750W PSU overkill or just perfect? Otherwise I'll go with the 600.
Link to 750W - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Link to 600W - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
More about : power supply overkill build
January 10, 2014 8:32:08 PM
Personally, I have had good success with Corsair and the 750W is only $10 more so I don't see why not to get it.
January 10, 2014 8:37:33 PM
Corsair makes a good PSU. You can never go wrong with more power. Who knows you might upgrade. Although the CX is on the lower end they are still quite reliable. I would do the 750W in a heart beat, it's modular.
January 10, 2014 9:23:13 PM
Indeed. Enjoy
