Hi guys, yesterday I found my front fan in my 600T case had stopped working and after plugging it direct to the motherboard and solving the problem, it got me thinking I'd like to replace the fans.
Ignore the fact that there was a problem (it's a controller problem), what I'm looking for are two 200mm fans and a 120mm fan, preferably with blue LEDs.
The first problem is that I don't think you can replace the top 200mm fan because only a 200x20mm fan will fit (or am I wrong?). I couldn't find any 200x200x20 fans to replace that one, so I guess I'll just be replacing the front 200 and the rear 120.
So onto the front 200mm. From what I can tell, the best 2 choices are either the CoolerMaster Megaflow or the BitFenix Spectre Pro LED. Do you guys have a recommendation on either? I'm leaning toward the Megaflow since it's almost 50% quieter.
Now for the 120mm at the back, I'm not sure what I want to go with. I'm thinking about the Spectre Pro LED (same link as above), but from googling around a bit there seem to be a lot of options and I'm a little overwhelmed... Anyone have any good recommendations for a blue LED 120mm fan?
Looking forward to any responses, I'm getting a bit excited now that I'm started to do even minor PC mods
