I have an issue with my monitor (Asus MX279h) displaying 'no signal'. I know that the monitor was working fine but now it has suddenly decided to not display anything from my pc and is just giving the no signal screen. The monitor is working fine on another computer so I am pretty sure it hasn't broken, and my pc is displaying fine on a different monitor so I don't think it would be to do with the pc.
Things you probably want to know:
I am using a GTX 770 graphics card to connect to the display.
I am connecting using a HDMI - HDMI lead.
I haven't changed anything on pc or anything about how it is set up recently so I'm not sure what the problem is.
Recently the monitor was having a bit of trouble and showed the no signal screen but after i turned it on and off it picked up the signal just fine as was working as intended.
I really am not sure what the problem is, my only assumption is that its something to do with the cable but i'm not sure. Any help would be greatly appreciated.
Thanks in advance.
Hilly
Thanks in advance.
Hilly
