Best case for custom water cooling system
  • Cooler Master
  • Cases
  • Systems
  • Water Cooling
Last response: in Systems
January 15, 2014 3:36:37 AM
hi guys
well this kinda weird question
i have haf-x coolermaster case
should i buy cosmo to coolermaster case so i can build a custom cooling system
whats ur word ???
thank you in advanced
cosmo II
http://www.coolermaster.com/case/full-tower-cosmos-seri...
Haf-x
http://www.coolermaster.com/case/full-tower-haf-series/...
More about : case custom water cooling system
January 15, 2014 4:20:39 AM
I would stick with the Haf-X.
January 15, 2014 4:58:26 AM
Doesn´t CM also have that Stacker thingy?
January 15, 2014 9:31:46 AM
YES. The Haf Stacker is a GREAT option. But seeing as you already have a HAF X, i'd just keep it. You have enough room, unless you want a few more hard drives and big radiators for your GPUs. If you just have one gpu, I'd stick with the HAF X.
