O OllieG_98 Honorable Jan 16, 2014 6 0 10,510 Jan 16, 2014 #1 My computer will not send signals to my monitor
Hackeey Honorable Dec 16, 2013 27 0 10,540 Jan 16, 2014 Solution #2 have you checked with another system or tried other cable?? Upvote 0 Downvote Solution
O OllieG_98 Honorable Jan 16, 2014 6 0 10,510 Jan 16, 2014 #3 Hackeey : have you checked with another system or tried other cable?? Upvote 0 Downvote
O OllieG_98 Honorable Jan 16, 2014 6 0 10,510 Jan 16, 2014 #4 Hackeey : have you checked with another system or tried other cable?? Upvote 0 Downvote
O OllieG_98 Honorable Jan 16, 2014 6 0 10,510 Jan 16, 2014 #5 No I have to tired any other device or monitor as I have 1 dvi cord and that is all Upvote 0 Downvote
Hackeey Honorable Dec 16, 2013 27 0 10,540 Jan 16, 2014 #6 OllieG_98 : No I have to tired any other device or monitor as I have 1 dvi cord and that is all okay then try.. on the other end i think may be the problem is with your ram that is why the computer is not sending any signals to the monitor Upvote 0 Downvote
O OllieG_98 Honorable Jan 16, 2014 6 0 10,510 Jan 16, 2014 #7 Hackeey : OllieG_98 : No I have to tired any other device or monitor as I have 1 dvi cord and that is all okay then try.. on the other end i think may be the problem is with your ram that is why the computer is not sending any signals to the monitor Upvote 0 Downvote
O OllieG_98 Honorable Jan 16, 2014 6 0 10,510 Jan 16, 2014 #8 I have tried the other end of the cable but it makes no difference and I will try the ram after as I am nnot home Upvote 0 Downvote
Hackeey Honorable Dec 16, 2013 27 0 10,540 Jan 17, 2014 #9 OllieG_98 : I have tried the other end of the cable but it makes no difference and I will try the ram after as I am nnot home okay then may be the ram is malfunctioning Upvote 0 Downvote
