For the Bitfenix Prodigy, the black seems to have more airflow with the mesh front and side grill, but some of the other color case options have a window on the side (no holes) with the soft touch front. I also found out the handles are removable, this all struck me since I don't really know how the following would work.
1. The graphics card obviously needs to expel heat somewhere, if there is a flat window in front of it rather than a grill, how much does that effect the card and tower all together?
2. Say I were to put a 230mm fan in the front (behind the soft touch), even though there is no air flow would the fan still be cooling? Is the purpose diminished?
3. If I were to take off the handles and lay the tower flat on a desk (the power supply takes air from the bottom and there is a dust filter included with the case), since there is no flow there either will the supply be cool at all as long as the surface itself isn't hot?
