When replacing a power supply unit, if the new unit says it has a 20-pin connector for the motherboard, will all 20-pin connectors fit the same way?
I've got an old Compaq EVO D310. Original power supply unit:
model: DPS-250RB A
220 Watts
20 PIN (motherboard connector)
1 x 4-Pin CPU Power Connection
4 x 4-Pin Molex
2 x Floppy Disk Driver Power Connection
+3.3V@15A, +5V@11A, +12V@5A, +12.8V@7.5A, -12V@0.15A, +5VSB@3A
Motherboard parts diagram is here: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00571576/c00571576.pdf
I want to replace it with this:
model: HEC 350W Power Supply - 80+ Bronze (HEC-350TA-2RK)
350 Watts
1 x 20
1 x 4-Pin Main Connector
2 x 4-Pin Molex
1 x Floppy
4 x SATA
+3.3V@21A, +5V@15A, +12V1@14A, +12V2@14A, -12V@0.3A, +5VSB@2.5A
Not sure what these specs mean, e.g., +3.3V@15A vs +3.3@21A. Is this about efficiency more or less?
Unit size: These are both labeled as ATX form factor, but I'm not sure if the HEC power supply unit is the right size for the original EVO D310 case.
model: DPS-250RB A
220 Watts
4 x 4-Pin Molex
350 Watts
1 x 20
2 x 4-Pin Molex
1 x Floppy
4 x SATA
