First my current PC specs
CPU: AMD FX 8320 3.5Ghz (It overclocks by itself to 3.7Ghz and (4.Ghz rarely))
GPU: NVIDIA GTX 770 stock
RAM: 8Gb or G. Skill Rip Jaws
HDD: 1st HDD is a 500Gb 7200Rpm drive and the 2nd HDD is a 1TB 7200Rpm
Motherboard: ASUS M5A78L-M LX PLUS
Disk Drive: 1 standard Read Write CD/ DVD drive
PCI: USB 3.0 expansion
USB: I have a keyboard, Wireless mouse, and Speakers plugged into USB Slots
PSU: 700w VisionTek
I'm going to upgrade to a NVIDIA GTX Titan and I was wondering if I need to get a higher wattage PSU. Keep in mind I'm not running my CPU and GPU at max load together. I do render videos and play games. I also don't plan on upgrading my PC anymore after this.
If anyone has a similar set up (CPU, GPU, and RAM wise that is) can you tell me what PSU you use.
Thanks in advance.
PSU: 700w VisionTek
Thanks in advance.
