I finished building my first pc(Power-color AMD 7870 GHZ + FX 8350+M5A97) today. Everything went smoothly. I downloaded Windows 7 but the problem is that I cant change my resolution to 1920 by 1080. I have an asus vh236. When i go to change the resolution it says for the display "Generic non-pnp monitor on standard vga graphics adapter" and the max it'll go to is 1040 x 768. Is it that my computer is not recognizing the 7870 (which has its fan spinning) or drivers not updated or something else? I think its a problem with the gpu as it only shows up as "Standard VGA Graphics Adapter." Thanks for the help. Much appreciated
