Parts are:
Case: Phantom 530
Mobo: Asus Maximus VI Hero
CPU: i7-4770k /w stock cooling
GPU: EVGA GTX 780
RAM: Corsair Vengeance Pro 16gb (2x8)
HDD: 2x Toshiba 2tb 7200 rpm SATA III
SSD: Samsung 840 750gb
PSU: Corsair CS-750w
Asus DVD/CD Drive
5.25'' card reader
Monitor: AOC 2ms 27'' 1920x1080
Keyboard: Steelseries Apex
Mouse: Digital innovations 5 button wireless mouse
Speakers: 6 piece logitech 5.1 channel speakers
16gb USB 3.0 Flash Drive
2 140mm fans (One for side panel, one for front)
5 120mm fans (2/2 on underside, 2/3 slots used on topside, 1 fan in the internal pivot fan holder)
Anti-static wristband and surge protection power strip
Dustoff duster and screen wipes
Windows 8.1 Pro OEM
Stardock's Object Desktop Suite and ObjectDock
Fraps
I also bought a $400 laptop pretty much as a non-gaming companion for the PC. Gaming I would only do on the PC anyway so I didn't feel the need to spend extra on the laptop. I would like to make sure this all is what I need. If something isn't right, I have 30 days in which I can return it and choose a different part.
I know how to do basic part swapping... and after research, I think I understand building one from scratch. I would like to know some of the more advanced or obscure tricks and tips. Everything from setting up a good thermal monitor setup, whether it's hardware or software... Getting up to date with the best programs out on the market for various tasks, both the payware and open source leaders, and whether or not the paid one is worth it or not... System processes worth gutting out, and those worth using... No advice is too in depth as long as you lead me into it.
Key Questions:
During hardware install... Should I flash the bios or upgrade any firmware?
After hardware install... I'm assuming I'll download all the freshest drivers on my laptop then flash drive them over. Are there any easily missed or especially important things to keep in mind while doing this?
After driver/bootup phase: What processes should I trim from the startup? Is there a good list of exactly what each one does and what the criteria is for wanting it disabled? I also want to remove the libraries and generic, irremovable personal folders like pictures and and music and documents in the C drive, along with navigation pane links. Bottom line is I want a clean, unbloated system, and I want to understand each part of it that is at work, and trim the ones that aren't.
After the trim and tweak phase... What programs should I focus on getting? Currently, I have the paid ones listed above in the build, and I also use:
Firefox
Freecommander (not sure if I like it)
Rainmeter
CCleaner
And uhh... Well to be honest, everything else is outdated, much going back as far as xp... It's been a long time since I've had this kind of money to invest in tech. So really, if someone could verse me in all the best programs to fill out a good rig, lay them out there..
Thanks in advance to anyone willing to advise me with this. Sorry if I am long winded or difficult to understand... I am autistic, with an abnormal ability for language and math... Figure software development lines up with that pretty well as a career path.
Case: Phantom 530
GPU: EVGA GTX 780
Asus DVD/CD Drive
5.25'' card reader
Windows 8.1 Pro OEM
Fraps
Key Questions:
Firefox
Rainmeter
CCleaner
