My goal is as good as a computer as possible, under $1000.
Parts found so far:
Case:
Motherboard:
CPU
GPU:
HDD:
RAM:
Disk Drive:
Sound Card: (I do not know if this will work, I know nothing about sound cards, I just found it.)
OS:
http://www.amazon.com/Windows-Premium-System-Builder-Ve...
I do not need a keyboard or mouse.
I plan to buy a 22 inch HDTV as a monitor from Walmart so I can see it before I buy it.
What I ask of you:
Will these parts all work together? (In example: Motherboard, GPU, CPU, Sound Card, etc. Are they compatible?) And will they fit in the case? Do you suggest a different case? I cannot go above $50-$100
What am I missing?
Parts found so far:
Case:
Motherboard:
CPU
GPU:
HDD:
RAM:
Disk Drive:
OS:
What I ask of you:
What am I missing?
