I already know the answer to this riddle, I think, I just want to see if anyone else can figure it out. Think of it as a brain teaser. Here's the case:
Metal case, older
ECS GF8200-A mobo
Phenom II x4 940 (AM2+ version)
5 GB DDR2 cheapy style RAM
MSI Cyclone GeForce 460 768MB video
Rosewill (Capstone) 450W PSU (brand spanking new)
3x DVD-RW drives
1x WD IDE 350GB Hdd
3x SATA Hdd (various brands and sizes)
No Overclock currently, everything at stock speeds.
Tower style cpu sink with dual 80mm fans
3 USB ports in use (small items ie: keyboard, mouse, sd card reader)
2x 80mm front fans for Hdd cooling
1x 120mm x12mm? LED fan, top, exhaust
2x 120mm x 24mm? (big mamma jammas) side case intake
1x 90mm x30mm? (roughly, another biggun) exhaust behind cpu sink
Now for my conundrum. I run stress tests (checking for temps) at various points during the day to make sure the system can handle the coming apocolypse that is Arizona summer. So far no issues. Until recently, it seems.
As long as I leave the side cover and rear exhaust fan off, I don't have any problems. >>>If I put ONLY the two side 120s on, no problem.>>>>once I connect the rear fan, I get lockups, slow downs, and the bios reports AHCI issues (hard drives not loading up or reading correctly)
Now, I have run the numbers, and THEORETICALLY my system should have no issue. My question lies in the rear fan. It is currently connected to the board by the RPM and PWM wires, while the power and ground run out of the PSU directly. Does the Blue PWM wire actually use power? Or is it only a low level switch to ground (variable of course) Why does this one fan alone cause issues?
The PSU is rated at 450W, which in theory means it SHOULD be able to handle a teeny bit more. Either way, I don't seem to be surpassing its capabilities with the current hardware, considering that the dvd drives use negligible power on startup, and all the rest of the hardware comes out to around 400W under full load. Even taking into consideration startup amperage of the fans, should my PSU still not be able to handle this stuff?
Metal case, older
ECS GF8200-A mobo
3x DVD-RW drives
1x WD IDE 350GB Hdd
