hello guys here is my 1st tower build
600T, GTX760 SLI, i5 3570k i belive, Recon 3D sound card, 2 ssd and 1 hhd, 8gb corsair vengeance, and z77 v pro
after a few month of decision making i have finally decided to build water cooling and drop the coolermaster v6
the main reason for me to do this is to have fun and make the tower looks nicer
and i am looking for cpu cooling as for now, but would like to get the set up enough to add 2 gpu water block later on
after a few research i have ordered the xspc Reservoir w/ liang D5 MCP655 pumps
and xspc water block with led (just because it looks nicer)
As for radiator i have no idea where i should put it
i am looking to install internally from what i'm looking at a 2x120mm radiator should fit the top fine
but does 2 120mm push fan works fine on it or i have to add 2 more for pull.
if that doesnt work should i just get two 1x120mm radiator install one for the front and one for the back?
[/URL][/img]
like i said the reason i am looking for a bigger radiator is for down the road to add 2 gpu block
any suggestion would be greatly appreciated
thank you
ps any slim radiator, good tube, and fitting for suggestion? i am looking at xspc ex240 as for now.
not sure what are some good fitting and tube for the set up.
thank you
