Solved
I need help to find good parts for my pc
  • Build
Last response: in Opinions and Experiences
March 6, 2014 4:23:46 PM
i am trying to build my own pc, for mainly gaming, but i don't know if the parts will work together? If you think i should change any of my parts, what part an if you have a better idea. Thanks
http://pcpartpicker.com/p/35xpr
More about : find good parts
March 6, 2014 4:30:53 PM
I've no idea what you want to use it for or your price target (it's excessive for gaming), but it's a powerful, highly overclockable build and should all work together. I feel considering the cost and specs of the other components, you've skimped a bit on the PSU and monitor.
m
l
Best solution
March 6, 2014 4:32:13 PM
well, you forgot to select ram. also MAKE SURE you get a 64 bit version of windows. and if this is a gaming pc, then you can get about 95% of this performance for $300 less. also, for the ram, i would get either 8gb (2x4gb) or 16 gb (2x8gb), depending on your budget and needs. you do not need an i5 for gaming, and i would get a 1tb hdd and either 128gb or 256gb ssd to boot OS and games from (if its for gaming). if this isnt for gaming, then please tell us what it is for.
March 6, 2014 5:29:20 PM
What are you going to use this system for? If your not even sure what parts will work together I don't suggest you try to assemble this $2K machine yourself. 1st off if your building this for gaming a i5-4670K is all you need not a 2011 rig. A GTX 770 is good you I don't really know why you need a GTX 780. This system won't run with out RAM I don't see any listed I would suggest DDR3-1600 8GB Kit. Change the O/S to a 64 bit version, and a $250 headset, wow are you sure you need that? But seriously this seems like project you need some help with. Are any of your family or friends experienced in assembling computers?
m
l
