Solved
What power supply should I get for this build?
  • Graphics Cards
  • AMD
  • Build
Last response: in Opinions and Experiences
March 14, 2014 2:09:44 PM
Hi everyone I was wondering how many watts I should get for my new pc build
Specs:
Graphics card: amd 7750
Motherboard:GIGABYTE GA-970A-D3P AM3+/AM3 AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
CPU:AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W 6-Core Desktop Processor FD6300WMHKBOX
Memory: Team Elite Plus 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
More about : power supply build
a b U Graphics card
March 14, 2014 2:14:18 PM
500w is good . . buy seasonic, antec or corair(GS600) cause it is a little cheaper and good quality unit
m
l
Best solution
a c 235 U Graphics card
a c 147 À AMD
April 5, 2014 5:03:37 PM
You can work it out yourself at - http://extreme.outervision.com/psucalculatorlite.jsp
