I have GTX 760 with the current drivers. I have an Acer X173W monitor (old monitor) which is 1440 x 900. I have a VGA to DVI adapter because the old monitor only allows VGA.
After building my PC I plugged everything in, booted for the first time and installed all the drivers. Everything was running great and the resolution was correct. Recently, I move my PC to another desk, which of course required removing all the cables (mouse, monitor, keyboard, speakers, etc.). After moving everything to where I want it, I plugged everything back in and booted it. As soon as I booted I realized the resolution was wrong and I couldn't find the correct one in the settings. It says 1024 x 768 is the native resolution which is obviously WRONG. I looked for help online and went about with solutions I found. I re-installed drivers (graphics card), unplugged, reboot, customize resolution, try all resolution, change from small to medium to large in Personalize, and other stuff that seemed basic. NOTHING WORKED! Please help! It was fine before I unplugged it. I don't understand what could possibly be wrong.
