Hi,
I apologized if this has already been asked but I've been searching and can't find the answer.
I have a Xion 850w power supply which has 2 - 8 pin pci-e slots, and I also have a gigabyte nvidia 770gtx graphics card which is also 2 - 8 pin pci-e slotted. I have been having a difficult time because the power supply only came with one 6pin - 8pin pci-e cable and one 8pin - 8pin pci-e cable. I've tired ordering 2 different 8 pin to 8 pin pci-e cables from separate companies that I purchased and neither worked. I will plug them in and turn on the computer and it says "please plug in the appropriate pci-e cables for the graphics card". Should I get a 6pin - 8pin adapter to plug my 6 pin cord into the power supply? I'm not sure what I should do and I'm getting extremely frustrated.
Thank you.
Thank you.
