Amp pull from device with full battery vs partial battery
  • Battery
  • Devices
Last response: in Other Consumer Electronics
March 25, 2014 10:10:18 AM
I have many of the same device. Nexus 7 in particular.
I'm trying to make sure all my adapters, cables and devices are charging correctly.
I need to know if there is a difference in amperage pulled with the battery is full compared to if its not pulled. does the device still pull the same amount and if its full will the Amps fluctuate a lot or just a little.
More about : amp pull device full battery partial battery
March 25, 2014 12:32:44 PM
With the load (impedance) remaining the same, the current will decrease as the voltage decreases.
Ohms Law: I=V/R
March 25, 2014 2:05:42 PM
Hi
Yeah this by clutchc but just to clarify that it is the difference in the voltages of the battery and the charger that decreases as the battery chargers and so the current decreases as the battery voltage (charge) increases.
