Sign-in / Sign-up
Solved
Do I have to have a dedicated sound card for my video card to relay sound trough an HDMI
  • Speakers
  • Graphics
  • Graphics Cards
  • Monitors
  • Sound Cards
Last response: in Displays
March 25, 2014 6:47:05 PM
Ok , so I have a pretty nice 1080p HD monitor, it has speakers that are surprisingly good for monitor speakers, and tomorrow my new gaming PC will be coming in! It's my first, so I'm not entirely sure what I should expect sound wise. I did NOT opt for a sound card and I just stuck with an onboard sound... Thingie. I don't know f you technically consider that a sound card. Anyway. I have obviously have knowledge about HDMI's, because I own consoles and such, but I don't know if my card will relay the sound. This could be bad, because I don't want to buy speakers, and I don't want to always wear headphones, AND I record with an HD PVR 2.
So will it work without a dedicated sound card? I have an Nvidia GTX 660 2GB. And on a side note, do I have to have a dedicated sound card for a USB mic to work? Such as a Blue Snowball, which if I remember right, has all it's own drivers.
More about : dedicated sound card video card relay sound trough hdmi
a b U Graphics card
a b C Monitor
March 25, 2014 6:52:34 PM
no, as long as your mobo is capable of sound, it'll be output through the HDMI connector, up to 7.1 surround. I originally used the optical output of the mobo, but this is not dolby encoded for games, only movies, hence no output for games. I then realised I should just use HDMI audio.
m
l
Best solution
a b C Monitor
a b U Graphics card
March 25, 2014 7:49:17 PM
If you use HDMI audio, then it will use the internal sound card built into the video card for playback.
If you want to use the integrated sound (on the motherboard), then you will need to connect separate audio out cables from the motherboard to the TV. (At least I think you can't route your system sound through the HDMI ... aka I think it can only use the one built into the video card, but I never actually tested that theory. :)  )
Also, when you get the computer setup, click on the sound icon on the taskbar, go to "playback devices" and you can chose to enable/disable either your TV/HDMI audio or your onboard motherboard audio.
