Dear All
Thank you for taking time to look into my request.
I am trying to build a system to be used for render
My configuration is
CPU: Intel Xeon E5-2660 2.2 ( dual processor )
Motherboard: Asus Z9PE-D8 WS
RAM: 32GB ECC DDR3,1866 MHz
Case: Thermaltake Chaser A71 Full Tower
Power Supply: Silent Pro M2 1500W
My Question is that i am planning to use 4 cards of Asus Nvidia gtx titan 6GB
i have read that each card when used at its maximum, uses 350W
The question is:
will a 1500 watt power supply be enough, or is there any other way to maximize power supplies
considering that, i might upgrade to newer cards later on if they become available.
like nvidia geforce titan Z
i hope i was clear with what i need and thank you for trying to help
My configuration is
The question is:
