Hi. So today I bought myself a new mobo because my old one got fried. (had an Asus H87 Plus and bought a Gigabyte GA-Z87-DS3H). I built my system on the new mobo and gave it a try but GPU fan started working all out 100% making very loud noise and I got no display at all. However I could still hear one beep which means that system POSTed successfully. I can even blind type my password and then hear Windows starting up which is definitely weird. GPU (Palit GeForce GTX 760) worked fine with my previous mobo.
Things I tried:
- Plugged monitor cable into mobo; everything works perfectly, I get display.
- As many have suggested, checked whether GPU was fully inserted into PCIe slot and whether the two 6 pin power connectors were plugged.
- Took out the battery for a couple of minutes in order to reset BIOS to no avail.
- Disabled integrated graphics in BIOS and then tried to put back my GPU. Same thing.
- Installed chipset drivers from disk that shipped with the motherboard. Still, nothing.
- Default display source in BIOS is set to the PCIe slot.
Faulty GPU? I don't know, it's only 5 months old and it worked fine with the same PSU and RAM I'm using now on this new mobo. Any other suggestions besides trying out the GPU on another system?
Full Specs:
Gigabyte GA-Z87-DS3H motherboard
Core i7 4770
8GB DDR3 RAM
Palit Nvidia GeForce GTX760
500GB WD Caviar HDD
Chieftec SmartSeries 700W PSU
Things I tried:
Full Specs:
Core i7 4770
8GB DDR3 RAM
500GB WD Caviar HDD
