I had built a mineral oil cooled computer (totally not worth it, btw) and it stopped working. I de-mineral oiled it and put it into a regular case. The heat spreaders on the RAM were falling off because the mineral oil made the rubbery stuff swell up and the adhesive dissolve. So I installed the RAM that was in the computer before I upgraded. I had 16 GB, have 4 GB now. After doing that, I could once again hear the beeps from the speaker - eight of them. So I put in the video card I had in the computer before I upgraded. It's a Radeon 5700 (5770?), I'm not sure the model of the failed one but it was also an ATI chipset (7xxx?)
So I turn the computer on and everything seems good. All the startup programs load and it took the normal amount of time. I tried to play a game of StarCraft II and it would not load. There was a popup message about the paging file - I had used Asrock's Xfast RAM to make a virtual drive that I put the page file on because there was still a page file on one HDD when I set the size to zero. Since I don't have RAM to spare right now, I set the page file to system managed. Since those changes aren't saved until restarting, I clicked restart thinking it couldn't hurt to restart. The computer shut off. Only the fans and power light would come on. No beeps, the power lights on my monitors stayed orange (no input). That was at 4am this morning, so I went to bed. After coming home today, I tried once more to turn it on before throwing it back into the oil and setting it all on fire. So here I am typing instead of explaining myself to the firemen...
Last night I only tried starting StarCraft, but after trying more stuff, Steam will not load. Path of Exile seems to hang on the load screen, I never really played it, and I remember it did take a while, but it's said "checking resources" for five minutes now. Several of my programs won't save a file to any disk or flash drive. They give various messages, Freemaker says the HDDs are full (400-some GB free across 3 drives), 7zip says there's no file selected when I hit extract, Paint says the save process was interrupted. Firefox can download just fine. I can move files between drives, I can defragment.
Device manager recognizes all the correct hardware and there are no error messages.
What could cause so many different programs to have problems? The HDDs are all the same, possibly plugged in to different connectors, but they all seem to be fine as far as reading/writing in Explorer.
Thanks for any help
-Jason
Edit: One additional thought... C: is definately plugged into the same connector it was before, which is where StarCraft is installed
Thanks for any help
-Jason
