Hi All,
So I have finally built my first gaming PC. Built it the other week, so far running great and am loving it. I just wanted to check my system temps. I'm sure what I have is fine but I want to know what is considered too hot and at what point I should be concerned if the temps are rising.
This is currently a no OC build with everything running as stock.
So I have:
CPU: I7-4470K
Cooler: H100I
Case: Corsair 500R
GPU: EVGA GTX 780 with ACX cooler.
I have the 3 case intake fans and the exhaust fan at the rear. I also have the H100i running in exhaust.
At idle my temps are
27-30 for CPU
20-22 for GPU
As I said I think these temps are fine but just want to know what is considered too hot. I may OC in future so it would be good to know.
Thanks
So I have:
CPU: I7-4470K
Cooler: H100I
Case: Corsair 500R
27-30 for CPU
20-22 for GPU
Thanks
