Closed
Plextor M6S And M6M SSD Review: Revving Another Marvell Engine
  • SSD
  • Storage
  • Plextor
Last response: in Reviews comments
a b G Storage
April 10, 2014 4:04:06 AM
Plextor is launching two new SSDs under its M6 banner. The M6S and M6M lean on Toshiba's new A19 flash and Marvell's updated 9188 silicon. Together, the two features should help the Japanese nameplate mix value and speed. Today, we'll see if that's true.
Plextor M6S And M6M SSD Review: Revving Another Marvell Engine : Read more
More about : plextor m6s m6m ssd review revving marvell engine
April 10, 2014 6:47:47 AM
I know there are slight performance differences between models and manufacturers, for the home user the discrepancies matter very little other than lifespan. It all comes down to price point for non-commercial application, not sure where this really fits in the product stack.
Score
April 10, 2014 8:21:04 AM
The Marvell 88SS9188 controller in the M6S is only capable of addressing 4 NAND channels at a time whereas the 88SS9187 (Crucial M500, Plextor M5Pro) and 88SS9189 (Crucial M550) are capable of addressing a full 8 channels. I would expect the Plextor M6Pro to use the newer 88SS9189 found in the M550 to be able to address 8 channels of NAND and support up to 1TB drives using 128Gbit NAND.
Score
April 10, 2014 8:42:36 AM
Clean looks... ok update for the M5S... here hopping M6P will have something on its sleeve performance wise. I liked the Plextor software (its like a bonus for some people... ).
But I still have the Samsung 840 EVO on my list, after all, when the dust settles, they both perform very well in a notebook for a regular joe, but the EVO has the price to beat.
Since my Crucial m4 is not dead... I will wait... mainly for prices to go even lower so I can get a higher capacity model instead of the best of the best.
Score
April 10, 2014 12:41:02 PM
Why not compare the Samsung EVO 840?
Score
a b G Storage
April 10, 2014 1:51:39 PM
So we weren't able to get confirmation from Plextor or Marvell, but it's probably the case that the 9188 is a cut down four channel version of the 9189. It's all the more annoying, because this is the third review in a row with new Marvell silicon but no actual info from Marvell.
We have a pretty good idea of this from looking at the 9174 4 channel used in the UltraPlus vs the 8 channel 9175 used in.... pretty much everything else ever made... that the 9188 is a four channel version of the 9189. But we don't know how many CEs per channel it has, or much else for that matter.
However, we do know Plextor's M6 Pro will have a 1 TB version, also with A19 flash. Plextor reps told me as much at the 2013 Flash Memory Summit. That was last August though, so I think there have been some delays -- either with Marvell, Toshiba, or both.
Regards,
Christopher Ryan
Score
a b G Storage
April 10, 2014 1:58:11 PM
If you're referring to the 128 KB sequential and 4 KB random performance, I'm trying to keep those clean. I'd much rather throw down on matchups like this in more important metrics. However, with TRIM testing out this go around, the EVO v. M6 angle got downplayed. It's an oversight.
Regards,
Christopher Ryan
Score
April 10, 2014 6:37:42 PM
I really wish write speeds would actually make a jump.
Score
a b G Storage
April 10, 2014 9:51:30 PM
For sequential writes, you can't do much better than 500 MB/s. The fastest M6M/M6S hits 440 MB/s, and so there just isn't much room left to grow unless you switch to PCIe-based storage or add a couple drives in RAID.
Regards,
Christopher Ryan
Score
April 16, 2014 6:38:22 AM
Great article! I'd like to see a summary comparison of your top ten drives listed in Tom's best SSDs for the money using your new benchmark. Most important is your omission of Samsung 256G Pro which has been your leader for 8 months cited now as "face meltingly fast". Any performance benchmark must include the Samsung leader. Love to see this right away from you!
Sincerely, Michael
Score
May 4, 2014 10:15:38 PM
Currently, the 128GB M6S is selling for $100 on Newegg, the 256GB M6S is selling for $165. The 512GB M6S is not listed.
Hard to justify buying these over the Samsung 840 EVO ($85 and $154). Actually, for most uses my first thought would be the Crucial M500 ($75 and $120). The M500 doesn't win on either performance or power consumption, but it is good enough that these will not be major issues for the typical user.
Score
