The only thing that is preventing me from buying my next computer is the answer to this question. Can you mount a 240mm or a 280mm CPU water cooler such as Corsairs H100 or H110 to the FRONT Intake Fans of the case IF the hard drive cage is removed?!
The website says the a 240mm or 280mm radiator can be mounted in the front. However does this include the H100/H110/Other CPU water coolers??
ALSO, I am aware that the h100 and the h110 both can be mounted to the top of the case. However would it fit in a Push/Pull Configuration? With low profile memory?? or just one or the other!?
THANK YOU SO MUCH FOR ANY ADVICE!!!
Case Tech Specs on Corsairs website
http://www.corsair.com/en-us/obsidian-series-450d-mid-t...
