GPU temp, usage, and fan speed high while monitor sleeping
- Low gpu temp but high fan use - Forum
- Core Temp, HW Monitor and Speed Fan showing very different temperatures - Forum
- High gpu usage and low cpu usage while gaming - Forum
- High temp and noisy CPU while gaming even i have discrete gpu - Forum
- Best software for monitoring cpu and gpu usage+temperatures while playing a game? - Forum
- SolvedGPU temp vs Fan speed Forum
- CPU fan runs so high while gaming, although I have a GPU; not the normal Forum
- GTX 680 SLI GPU Usage Drops No High Temps Forum
- SolvedMonitors shut off when playing games, fan speed goes high, have to force restart Forum
- High Cpu usage and fan speed??? Forum
- SolvedHow do I make Rivatuner show temps, usage, clock and fan speeds in game? Forum
- Blinking screen and gpu overheat (asus gtx 780 ti matrix) , ram frequency low , corsair h 110 fan start up speed is too high Forum
- SolvedHigh contrast between idle temps and while playing games (GPU) Forum
- GPU fan makes high-speed ticking noise when at a certain speed Forum
- SolvedTurning up fan speed vs leaving them low and having higher temps - which is better for my GPU? Forum
- SolvedGPU Fan / Temps Extremely High Forum
- Monitor GPU Temp while gaming Forum
- 4890 high temp and 100% fan speed, help please ! Forum
- SolvedWhy my cpu fans start running high speed when temperature of my gpu gets higher? Forum
- SolvedNeed to know about GPU temps and fan speeds.. Thanks! Forum
- More resources
