Best white Full Tower case with blue/red LED fans?
  • NZXT
  • LED Monitor
  • Thermaltake
  • Components
  • Inwin
  • Cases
Last response: in Components
June 4, 2014 8:57:48 AM
Thermaltake overseer white edition
Nzxt phantoms
or Inwin grOne?
More about : white full tower case blue red led fans
June 4, 2014 9:36:47 AM
You can always buy a white case, and get blue LED fans... what is your budget?
June 4, 2014 9:39:39 AM
My budget for the whole thing is £1400 with headphones, windows, mouse and keyboard. For the case around £100. I dont want to install anything as the ones i listed come with multiple led fans. Inwin has got 3, nzxt has got one and thermaltake i belive has got 2.
June 4, 2014 9:46:49 AM
I had one of the original Phantom cases an i loved it, the Phantom 820 takes everything that i loved about the original phantom and made it tones better.
June 4, 2014 9:49:00 AM
Thanks i will look into that one because i havent yet. I can see you are using gtx 780. How does it perform in games with your i5?
June 4, 2014 10:01:48 AM
sorry my mistake. your build looks cool. im looking for something similar but in white case with red or blue led fans. Later on i want to add more LEDs but for now i want to get the best parts possible and not spend money on extra fans and leds.
June 4, 2014 10:07:10 AM
Ok, it's easier to use LED strips for illumination, than it is using fans.
