Gigabyte GA-78LMT-USB3
USB 3 PROBLEM
Hi all,
I've just brought a Gigabyte GA-78LMT-USB3 motherboard, i've fitted it and installed Windows 8.1, everything was working fine, i also fitted a USB 3 card reader, (EVO LABS E-8343.0)
The USB port worked, each card slot worked fine. (card reader is internal and hooks up to the motherboard)
Until...
I installed the motherboard drivers, now i've installed them the card reader won't work, it will sometimes if i plug a mouse into it's USB port a few times, also the same thing with the USB 3 ports on the back, they work sometimes but not others.
However, if i disconnect the front panel USB 3 card reader, the USB 3 on the back works fine again.
So i'm guessing it's a driver problem, i've downloaded upto date USB driver (for the rev 5 i have black printed circuit) and i've done a Windows update and i've done a bios update. but still no joy.
Anyone else had this problem? and does anyone know how to fix it?
USB 3 PROBLEM
Hi all,
Until...
