Hello, I built a new PC recently and have a problem I haven't been able to solve. I have a Corsair H100i with the stock fans removed and replaced by Cooler Master Megaflows Red LED fans. When I first turned the PC on, I was able to get into the bios and everything was working, light on the H100i was on and the fans were fine, then I turned the PC off and back on. I had a couple problems with wires not plugged in correctly, and after fixing that the fans no longer spin and the LED's blink about once a second.
When I boot the PC, the Corsair logo on the pump lights up normally, and the LED lights on the fans stay on but the fan doesn't spin, then after a few seconds the pump light turns off and the lights on the fans start to blink. My build is:
CPU:i7 4770k
Asus Maximus VII Hero (Z97 Chipset Board)
PSU:Corsair RM750
GPU:GTX 780 TI
RAM:G.SKill Ripjaws 16gb 1866Mhz
Storage:Samsung 250gb SSD and Seagate Barracuda 3TB
OS:Windows 8.1 64Bit
Thanks in advance for any help that can be given.
(Note: I have tried installing Corsair Link but the fans just doesn't show up, and I have done the Windows 8.1 fix.)
CPU:i7 4770k
PSU:Corsair RM750
GPU:GTX 780 TI
