Hello
I know this has already been asked, but I still find all the configurations hard to understand being a complete noob.
I have a radeon 7950, which has 2xmDP, 1 DVI and 1 HDMI outputs. I currently have 2 monitors attached like this:
To connect the 3rd monitor I've tried these combinations but none of them work.
Config 1
(1) and (2) work only.
Config 2
Config 3
Config 4
Doesn't work at all (I tried both cables, and both ports, so can't be the cable/ports)
Anyone know what I'm doing wrong? It is just that 3 dvi's just won't work? (i.e. I have to use the hdmi - and if so do I need active or passive?)
Thanks in advance
DVI(monitor)->DVI(pc)
DVI(monitor)->DVI-to-miniDisplayPort converter (passive)
Config 1
DVI(monitor)->DVI-to-miniDisplayPort converter (active)
Config 2
Config 3
Config 4
Thanks in advance
