http://uk.pcpartpicker.com/user/Hagleigh/saved/FBCD4D
So I'm about to buy these parts.
The aim of this computer was for gaming where it can run new games such as BF4 on max.
My budget was around £750 excluding peripherals. I do not want an SSD.
I just wanted you guys to tell me what you thought of it before I click buy.
My main concern was whether or not to swap the gtx 770 out for the r9 280x. I know the r9 is cheaper but does it perform significantly better? I've also heard that it overheats alot and something about artifacts.
Secondly my cpu motherboard combo. I do not want to overclock so I was looking at the locked processors. Since the 4670 is similarly priced to the 4570 I thought I'd go for that. And for the mobo I honestly just picked one with good reviews that was compatible with my ram and cpu.
