Solved
Xbox360 to monitor audio issues
Last response: in Entertainment
June 23, 2014 4:44:10 PM
Hi, so i have my xbox 360 connected via HDMI(To xbox) to my monitor, which takes a DVI. I know that DVI doesn't take audio so I connected my speakers into my monitor. Now my monitor is an HP w2207 and it has built in speakers. Audio does not come from neither the built in speakers nor the speakers i plugged in. Will i need to buy a different cord for this, or is there a way around this so i don't blow more money on weird setups? The monitor takes AVI and DVI
More about : xbox360 monitor audio issues
Best solution
June 25, 2014 12:33:04 PM
some variations of dvi may not support sound but dvi-d does which is pretty common. i use dvi-d as my output of both video and sound going to my theater system.
check that it is dvi-d.
also check your sound playback devices to make sure that you have hdmi selected as your default device.
