My Build help with Chassis
  • Motherboards
  • AMD
  • Build
  • Cases
  • CPUs
What Case should i buy
Total: 1 vote
  • Thermaltake A31
  • 100 %
  • Cooler Master K380
  • 0 %
  • Other State in a new post
  • 0 %
June 24, 2014 1:03:16 AM
Hi,
i am soon to buy my new computer i have decided to go with
AMD A10-7850k = CPU
2x Patriot Signature 4GB RAM DDR3 1333mhz
WD 3.5 Blue 500gb HDD (unsure whether i need because i own many other hard drives but they are outdated i guess)
Thermaltake VP300A-A31 Case
AsRock Fm2A55M-HD+ (is FM2+ capable)
Corsair VS450 450w PSU
Now i know that the compatibility with the MOBO and Chassis the case is USB 3.0 and the motherboard only supporting USB 2.0........ Well i like the case and i like the mobo i know i can just spend an extra ten bucks for a USB 3.0 Motherboard but i am really unsure on. i don't like OC with Asus because i have had some failures with them before
Really i am in a loophole as with what to do any suggestions and also another case i have been eyeing off is the Cooler Master k380 i like the idea of it but seems to idk standard for what i would want
i basically want ideas and tips on my build and with the case, and i don't want to really spend over $600 AUD if possible
More about : build chassis
June 24, 2014 5:21:29 AM
Crap see i thought the 7850k supported all DDR3 memory types :L
June 24, 2014 5:28:08 AM
What would happen if i used a lower speed memory?
never had this problem before
June 25, 2014 8:01:23 AM
