Sign-in / Sign-up
Screen going to sleep but tower sounds to be running at full speed.
  • Sleep Mode
  • Monitors
  • Graphics
Last response: in Displays
June 29, 2014 9:08:19 PM
This is my first gaming pc build and it has been running well however recently my monitor will out of nowhere go black then show a going to sleep message the tower does not change at all and sounds to be running fulling i thought this might have been a cooling issue but in the bios about 2 mins later the cpu temp was at 55C and the system temp was at 35C idk whats going on please help hopefully its not anything to bad
Specs are
CPU: AMD FX6300
CPU COOLER: Stock
MoBo: Msi 970A-G43
Gpu: XFX Double D R9 270 925MHz Boost 2GB DDR5 DP HDMI 2X DVI Graphics Card
HDD; Toshiba 500gb 3.5 inch 7200RPM
RAM: Kingston Hyper X 4gb single stick
PSU: Corsair 500W CX500
More about : screen sleep tower sounds running full speed
a b C Monitor
June 29, 2014 9:11:44 PM
What are your specs? Also, is the monitor properly connected and secured?
m
l
a c 151 C Monitor
June 29, 2014 9:12:22 PM
It could be many things:
Try reinstalling or updating graphics drivers
Update your BIOS
if the top two don't work, make sure your connections in the PC are good.
What Is your cpu cooler?
m
l
