Has anyone ever tried to disassemble an AiO water cooler and tried to add more tubing? I want to locate the radiators outside of my case, but I'm not sure of a few things:
1) Can the small pumps handle the increased load/ distance?
2) Would adding a pump/ reservoir improve or destroy the pumps already in the system?
3) Is it even worth the effort to try to re-use the AiO systems I have or just build a system from scratch?
I work for a mechanical company and a few of my co-workers have been tinkering with the idea of using a refrigerator to cool the radiators or using a refrigeration coil to cool a sump of water in which the radiators will sit. Either way, I need more tubing length to explore the possibilities...
