Cabinet : CM Storm Scout 2 Ghost White
Motherboard : Asus]http://www.asus.com/Motherboards/H97PRO/specifications]Asus H97 Pro[/url]
CPU cooler : CM Hyper 212X
PSU : S12G 650W
Processor : Intel Xeon E3 1230 V3
GPU : Sapphire R9 290 Tri X OC
RAM : 4 GB x 2 Corsair Vengeance
My case comes with 120mm
2 led front fans [intake]
1 rear fan [exhaust]
I am thinking of adding another
2 blue led fans on side panel. [intake]
1 non led fan at bottom [intake]
2 non led top fans [exhaust]
So thats 5 additional fans.
I am wondering whether I should go with PWM fans and let the motherboard regulate it.
If yes , then can i connect 5 pwn fans on my motherboard?
Or
Use a fan controller with preferably led on/off switch like bitfenix hydra
Whats the most suitable cooling option?
Also what are the recommended 120mm less noisy fans?
PSU : S12G 650W
Or
