Samsung Galaxy Note 10.1 (2014) Review: Wi-Fi Vs. LTE
Smartphone Processors
Android
Tablets
Samsung
Last response: in Reviews comments
Anonymous
a
b
Ô
Samsung
July 7, 2014 11:58:44 PM
Today's review of Samsung's Galaxy Note 10.1 (2014 Edition) includes the LTE-capable and Wi-Fi-only tablets, allowing us to compare Samsung's own Exynos 5 Octa platform to Qualcomm's Snapdragon 800. Can either configuration usurp Apple's iPad Air?
Samsung Galaxy Note 10.1 (2014) Review: Wi-Fi Vs. LTE : Read more
More about : samsung galaxy note 2014 review lte
blackmagnum
July 8, 2014 1:05:19 AM
Farrwalker
July 8, 2014 8:33:50 AM
- Samsung Galaxy note 10.1 screen issues - Forum
- Could someone please advice me on buying my first Tablet ipad air vs Galaxy Note 10.1 or Tab Pro 8.4 - Forum
- Samsung Galaxy Note 10.1 or Asus Transformer Infinity 700 - Forum
- Xperia Z2 Tablet vs Galaxy Note Pro 12.2 vs Galaxy Note 2 Tab 2014 ed - Forum
- My S3 is connected to internet by wifi and my samsung note10.1 too.I would like to know about the IP address on each device.I - Forum
blueer03
July 8, 2014 9:30:08 AM
You need to proofread this big time. From page 9:
Samsung's Exynos-based Note 10.1 (2014 Edition) Wi-Fi holds its own against the Tegra Note 7, while the LTE version of the Note 10.1 (2014 Edition) again falls significantly behind its Snapdragon 800-powered Wi-Fi counterpart.
And this happens all throughout. The LTE is a Snapdragon, the Wifi is an Exynos. Keep repeating that to yourself as you re-write the descriptions and it will make this easier to read.
Score
Kevin Harrelson
July 8, 2014 9:54:21 AM
We got one of these for my son (age 13) to help with his school work. We got it from Best Buy and got the extended warranty. Both sound dumb, but it was actually a good move! The backlight has gone out on this thing TWICE. I happen to think that it is a lovely little tablet, but the backlight is a major reliability issue.
Score
Quote:
On page 7. Results: CPU Core Benchmarks:Your bar graph "MobileXPRT 2013" seems to be in error. For example, the text says, "Note 10.1 (2014 Edition) Wi-Fi leads with 300 points . . ." but the bar is the shortest and indicates less than 150 points.
This benchmark's sub-tests produce scores in seconds (lower is better), and the overall score is given as a typical higher-is-better score, so the lowest bar indicates the fastest completion. Sorry about the confusion, I'll look into other ways to represent this test.
Score
Quote:
You need to proofread this big time. From page 9:Samsung's Exynos-based Note 10.1 (2014 Edition) Wi-Fi holds its own against the Tegra Note 7, while the LTE version of the Note 10.1 (2014 Edition) again falls significantly behind its Snapdragon 800-powered Wi-Fi counterpart.
Good catch, thanks! Fixed.
Score
Tomtompiper
July 8, 2014 1:30:51 PM
The 2014 is almost 5 months old and has been superseded by the Amoled screened Galaxy Tab S 10.1 which wipes the floor with the opposition. http://www.gsmarena.com/samsung_galaxy_tab_s_105-review... Do try to keep up!
Score
Quote:
The 2014 is almost 5 months old and has been superseded by the Amoled screened Galaxy Tab S 10.1 which wipes the floor with the opposition. http://www.gsmarena.com/samsung_galaxy_tab_s_105-review... Do try to keep up! Actually, you'd think this has been phased out, but it's the current 10-inch Galaxy "Note" product, meaning it has the S Pen. The Galaxy "Tab" S does not - still unclear to me what makes the "S" stand out. I believe Samsung is literally attempting to offer an alternative product to every single other device in existence - complete mobile domination. I lost count of their current "Galaxy" line at 11 products, and that was awhile back.
The duo of Note 10.1 (2014)'s came in very handy both as comparison data in other articles and as testbeds for compiling our benchmark suite. Unfortunately, the article had to be pushed back several times, but the huge hardware difference between products carrying the same name was always something we wanted to illustrate, initially for the chipset-vs-chipset angle, but later for the optimization aspect as well. We're currently working through a small backlog of mobility articles, but each will be more timely than the last. My apologies.
Score
Blazer1985
July 8, 2014 6:22:38 PM
vaughn2k
July 8, 2014 9:03:24 PM
Ninjawithagun
July 9, 2014 6:53:09 AM
These benchmarks are fundamentally flawed. No where is there mention that both the Nexus and Apple iPad Air use lower resolution displays, which dramatically reduces the overall load on the CPU and GPU vs. the Samsung Note devices. The benchmarks are completely useless since an "apples-to-oranges" comparison is not a valid methodology for comparing these uniquely different tablets. And why was the new Samsung Tab S used instead of the year old 2014 Edition versions? Another "fail" on behalf of the author.
Score
-2
godnodog
July 9, 2014 11:23:53 AM
As a user of the Note 10.1 2012, I have to strongly disagree with the new multitasking sytem, as it is clearly a step backwards from what it used to be, now you can ONLY have 2 windows opened, as I, by not installing the update, can have 4 / 5 / 6 opened, obviously I don´t have them opened, but I frequently have 3 windows opened simultaniously, wich now I can´t have. Also it apperars that the multitask is no longer floating, agains mine that still does. I have experienced no problem whatsoever like you described "were slow, unresponsive, or just plain bad".
Score
wiltjk
July 10, 2014 7:18:21 PM
A key point of your review is that this is about a "pen" tablet. Not having used a physical keyboard since 2003, I am pleased to see some alternatives to the Intel/Windows dominated offerings.
It is a good review for apples to apples on the Samsung hardware options.
Would you suggest that this is "as-good-as-it-gets" for the few who prefer pen-based tablets? Any foresight in other pen based tablets?
Score
Zarathvstra
July 11, 2014 2:23:55 AM
Quote:
These benchmarks are fundamentally flawed. No where is there mention that both the Nexus and Apple iPad Air use lower resolution displays, which dramatically reduces the overall load on the CPU vs. the Samsung Note devices. The benchmarks are completely useless since an "apples-to-oranges" comparison is not a valid methodology for comparing these uniquely different tablets. And why was the new Samsung Tab S used instead of the year old 2014 Edition versions? Another "fail" on behalf of the author.Ninjawithagun,
Tablets are not modular like a pc... whilst it may have been good for the author the resolution issue with these benchmarks, an apples to apples comparison of the individual components would NOT help the user decide which unit as a whole is the fastest as indeed, they are NOT modular.
Score
Ninjawithagun
July 12, 2014 8:46:04 AM
Not true. Most (not all) tablets are in fact modular in that the CPU and GPU operate independently of one another. Case in point, the Apple A7 uses a dual-core 64-bit SOC processor and PowerVR G6430 graphics chip. The Samsung uses the Exynos 5 Octa processor with a Mali-T628 MP6 graphics chip. Your definition of modular is fundamentally flawed in that you think it pertains to physical ability for individual items to removed/replaced. Modular infers to the actual architecture of the system in that several different parts from different manufactures are integrated together to function as a whole unit.
Score
Zarathvstra
July 12, 2014 6:04:43 PM
This does not argue to the point. Here's a fact and the crux of the matter... An apples to apples comparison of gpu's and processors does NOT tell the user how apps will perform on tablet x when constrained by their other components be it amount of ram, screen res, gpu, cpu etc.
i.e. benchmarks are not "fundamentally flawed" (nor is my understanding and use of the term modular)
Score
apertotes
July 14, 2014 4:36:47 AM
szalkerous
July 16, 2014 9:21:49 AM
At first I thought there was something new, and I realized this is a review for a tablet I bought last year.
FYI, the KitKat update makes the SD card practically useless. Rooting these tablets is frustrating at best, and the KNOX system is the most terrible idea Samsung ever came up with.
Looking back, I should have gotten a Nexus.
Score
apertotes
July 16, 2014 10:06:38 AM
How can it be useless having 128 gb for music and videos/pictures? Maybe you can afford spotify and paying 15 dollars every month for an upgraded dropbox account, but many people don't, or even if they do, they do not have a reliable LTE signal 24/7.
Score
SoPhat VaThana
July 17, 2014 1:29:21 AM
Shalini Dixit
August 22, 2014 12:11:35 AM
Its awesome phone.
Samsung galaxy note 10.1 gives you best viewing experience, having multiwindow for multi tasking, sleek & portable design amd more. Check all features at Samsung India site.
http://www.samsung.com/in/consumer/mobile-phone/mobile-...
Score
- Samsung Galaxy Tab 10.1 vs Asus EEE Pad Transformer Forum
- More resources
