G
Guest
Guest
Hi guys, long time reader first time poster.
I have a speculation question/topic regarding liquid cooling systems.
In a loop the heat is transported to a radiator to dissipate the heat, would it be possible to have the case act as the radiator?
Maybe have the whole case designed as a heat sink by making it like a Matryoshka doll with a bimetallic material that absorbs on one side and transfers on the other, with fluid between for the loop?
That way the whole case would stay cool inside and move the heat to the outside and also be part of a cooling loop without needing an external radiator.
Thoughts? Crazy Thoughts? I'll take them all.
