GTX 780 Ti Dual-Monitor Problem...
AndreMarchi
6
Hello my friends, i've got some troubles finding how to plug my second monitor that is 1440x900 Samsung SyncMaster932 BW6 as a second monitor. Note: i already have a LG 22'' 1080p 60Hz running on the DVI-I port. So the remaing ports would be:
- 1 x HDMI
- 1 x DisplayPort
- 1 x DVI-D
Note that my samsung 17'' 1440x900 that i want to use has only VGA and DVI-I ports. I bought a DVI-D To VGA converter but it does not work because i was told that it's something about analogical to digital signal that doesn't work... Should i buy a HDMI to VGA to connect my 1080p monitor and just use the 17'' in the DVI-I port? What should i do? :??:
