I have purchased nearly all of my components. The only thing I have not purchased yet is the cooling for the CPU/GPU. I will briefly share the key components and then get into my issue:
Haf X Case
4790K CPU
GTX 780 6GB x 3
Noctua NF-F12 x 8
My reasons for 780 6GB GPUs are very specific to my 1440p, multiple monitor, sli configuration and I don't really want to get into that debate at this point. I really need some help determining a cooling method for this rig. As for overclocking, I am a set and forget type usually leaving it to an auto overclock or equivalent. I am by no means an OC hobbyist. I prefer gaming, photo and video post processing.
My only other priority is a rig that is as silent as possible. My understanding is these particular EVGA cards are very quiet so I'm not overly concerned even with a tri sli setup. Unless someone has a very different opinion about water cooling these cards, I will likely just use their stock fans. That leaves the CPU. I wondered if it made sense to set up a custom loop for just this or just maybe an H110. The only thing I have heard about the all-in-one liquid cooling kits is that they can loose liquid over time and introduce air into the system? Is anyone familiar with this situation?. Lastly, what would you different or is my thinking sound?
Thanks for any advice.
Haf X Case
4790K CPU
GTX 780 6GB x 3
Noctua NF-F12 x 8
