Does this graphic card is compatible with my power supply and motherboard ?
  • Power Supplies
  • Graphics Cards
  • Compatibility
  • Motherboards
July 20, 2014 1:15:43 PM
So I want to buy a new graphic, the SAPPHIRE AMD Radeon R9 270X PCI-E 2GB : http://www.pcworld.co.uk/gbuk/components-upgrades/graph...
And I wondered if it was compatible with my power supply which is 405 W and my motherboard which is a Foxconn H61MXL/H61MXL-K
Thanks for your help :)
More about : graphic card compatible power supply motherboard
July 20, 2014 1:24:24 PM
Your power supply is too weak to handle the 270x. You need a decent 500w psu at minimum.
Your mobo should be fine.
July 20, 2014 1:25:40 PM
ok thanks :)
July 20, 2014 1:26:11 PM
The minimum PSU required for this power hungry R9 270x card is 500W... The card will fit on the tower, it will suffice. Is not top quality but does the job.
PSU : SeaSonic S12G-550W -->http://pcpartpicker.com/part/seasonic-power-supply-s12g...
July 20, 2014 7:18:19 PM
If I or anyone else has answered your question please mark it as such. Thanks.
