Motherboard and Case USB Problem?
  • Cases
  • Build
  • Motherboards
Last response: in Sports & Wellness
July 26, 2014 12:50:33 AM
Here's my build http://pcpartpicker.com/p/KyzDjX. My motherboard has USB 3.0s but my case doesn't support them? I don't know what this means. This is my first PC build so it would be great if someone could help me!
More about : motherboard case usb problem
a b V Motherboard
July 26, 2014 12:55:04 AM
Okay, your Case does not have 3.0 USB ports. Only 2.0 Ports. Check your motherboard if the pins for front USB Ports are for 2.0 or 3.0. If it is only for 3.0, then I'm not sure if you can use the front panel. The back panel USB Ports are OK.
m
l
a b V Motherboard
July 26, 2014 12:55:47 AM
Oops. I think there is no Front USB Ports.
m
l
