Sign-in / Sign-up
Solved
Busted GPU, or monitor problem?
  • Gaming
  • Help Desk
  • Graphics
  • GPUs
  • Graphics Cards
  • Monitors
Last response: in Displays
August 2, 2014 11:26:37 AM
My monitor has been displaying these errors following gaming for the past couple of weeks. If I give up and come back the next day, they're gone. Here's a video showing what it looks like: http://
It's essentially a bar down a third of my screen that distorts everything downwards. Is this a GPU fault or something monitor-based? Any help will be much appreciated.
PC SPECS;
i5 3570k
8GB 1600MHz
ASUS GTX 650 Ti (non-boost)
More about : busted gpu monitor problem
Best solution
a b U Graphics card
August 2, 2014 11:40:32 AM
I would recommend borrowing a display from a friend or whomever, and try to repeat the issue on it. If the issue reappears on another display, it's the card, if not, it's the display.
a b U Graphics card
August 2, 2014 11:53:29 AM
Try a different display. If it doesn't work, GPU is done for. ASUS isn't too good at making GPU's by the way, Sapphire is though.
m
l
August 2, 2014 12:04:51 PM
Thanks for the help. Turns out the monitor was dead. At least it was the less expensive one (and I use a dual display, so I have another!).
m
l
